What do you need
Rumnhammer
What do you need
Hi all, just a note to thank you guys for letting me help you with the anti-drop bracket. I'm glad that it could be applied to the Mx3s.
In light of this problem being solved, I was wondering if you guys had any other little things that you think I could make to fill a need you have with your Mx3s.
Is there anything you would like to see for your cars?
as you know I don't have an Mx3 myself, but I'm sure I could adapt and make things using Wils car as the guinea pig.
Let me know, and maybe I can develop some things to fill your needs.
Chris Rummel
ps I still have shifter brackets left.
C
Chris Rummel
C
94 Miata R package with turbo
91 festiva L with B6T and everthing else modded too.
2008 Mazda 5
No MX3 but you can tell I am a mazda guy
2008 Mazda 5
Mnemonic
Affordable lambo door hinges
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
schuttie2002
How about good solid sway bar endlinks. I've heard of many other cars that get these custom made. Mazda rips you off with those suckers, and I could use a new passenger one.
Along with the endlinks, Im sure some people would be interested in some beefed up swaybars.
onderground_mx3
- mitmaks
heavy duty swaybars. better tie bars
Rumnhammer
stuff
I think the swaybars should probably be made by a company that has the bending equiptment to do that. That would be a bit beyond my abiltiys toolwise. The endlinks might be doable though, you have a pic of one?
I think I'd have to experiment making the lambo door hinges, as I haven't done that type of mod, That might be doable though, since the pics I've seen of the ones that are for hondas seem pretty simple. isn't there a universal lambo hinge avaliable?
What is a tie bar? some form of brace? I know what a tie rod end is. If you mean some form of under car bracing, that is definatly doable, how about something like that?
Anything else?
Chris
Anything else?
Chris
2008 Mazda 5
2008 Mazda 5
schuttie2002
I dont have anypics of the endlinks, but some people have costum made their own, so it should be easy for u to do. Um ask Will if he can show u an endlink the next time your around his car
- PATDIESEL
I think he is a welder not a CF guy, and that post about making new parts was some time ago. I haven't seen him on here since that anti-drop brackets.
Rumnhammer
parts
That's true I don't work with CF, primarly bits made of metal for me.
Chris Rummel
Chris Rummel
2008 Mazda 5
2008 Mazda 5
Don't know exactly what this is, but it has something to do with the hood clearance issue whilst using the Millenia Manifold and front strut bar.Mazdubber wrote:The one and only thing that can and should be produced is a set of on piece strut braces that clear the Millenia manifold.
Really don't have a clue here, but maybe somebody else on this forum could shed some more light on what I mean.
'92 GS
My worklog
My worklog
Me too. The swap is to be done in the wintertime, and I want to keep my front strut bar.mx almere wrote:I would buy it for sure.
This is the manifold I'll be using, and it's the MS8 style:
Picture taken from http://www.outlawengineering.com
'92 GS
My worklog
My worklog
