my car is trying to kill me
MI-Archangel
Ok, i have the klze with the ecu. My car has short ram intake and everything else is stock. Now it has been reving to 3000rpm quite often usually while idled. Now once it pins at 3000rpm I cant lower it i try tapping the gas i try launching with the clutch. It just sit there. When i am driving I feel a little jerk when it does it while im in gear. If i try to drive while it does it when iam idled my car just leaps forward and jerks around. Please help me this time...
- jschrauwen
Other info may be of substantial help, without which, it's just a crap shoot. IM??, TB?? VAF?? etc. What has been done aside from ZE and ZE ECU?
Check throttle cable adjusment.
Has a proper TPS adjustment been done since ZE install?
Have all vaccum lines been checked?
Have you checked for CEL codes?
If unsure of how to accomplish these tasks, info available and retrievable via search function. Key words; TPS, vaccum, CEL, cable, idle, surge.
g/l
*John*
g/l
*John*
- vozaday2000
ya it sounds like you might have your throttle held open a bit by the throttle cable. you want it to be tight but you want the throttle butterfly to be closed all the way.
MI-Archangel
lakersfan1
- jschrauwen
jschrauwen wrote:Other info may be of substantial help, without which, it's just a crap shoot. IM??, TB?? VAF?? etc. What has been done aside from ZE and ZE ECU?
That's it???? You have nothing more to offer? Sounds like it's going to turn into 20 questions before we get some equitable backround on this and are able to make any headway. There was a good reason why I put those questions to you. Since you haven't responded to the rest of the Q's, are we to assume that they haven't been done or that they are going to be done or that you don't know how to do them? Progress is going to be pretty slow if there is insufficiant backround.MI-Archangel wrote:ms8 manifold and tb
MI-Archangel
hey sorry I meant that was all that was done
Check throttle cable adjusment. * it is tight but has slack*
Has a proper TPS adjustment been done since ZE install? *mechanic installed engine so i doubt it*
Have all vaccum lines been checked?*nope*
Have you checked for CEL codes? *whats that, when he did swap he pulled no codes*
- jschrauwen
Since you acquired the services of a mechanic for the install, why wouldn't you bring a malfunctioning situation which appears obviously atrributable to his handiwork, back to him in the first place. This appears to be shotty work on the part of the installer and therefore should be referred back to him for resolution, IMO.MI-Archangel wrote:hey sorry I meant that was all that was done
MI-Archangel
- jschrauwen
So what are you trying to say? What do you mean by this? Sorry bud, crystal ball is on the fritz and I gave up trying to read minds years ago. Your best results are accomplished if you tell us a story .... a longggggggg story. Where you are at now, what has been done in the past and everything in between. Think of it as going into see a new doctor for an ailment. Personal/medical history (a complete history) is critical to a successful diagnosis. You've got a couple of unfinished items to reply to and while tending to that perhaps you can compile that 1.5 year's worth of data into some tangable resource material that we can help you with.MI-Archangel wrote:i got the car back from him over a year and a half ago.
- PATDIESEL
J is not being mean, but we do need some real heavy background to help diagnose a car without seeing it.
I'd guess TPs needs to be adjusted and the vaccum needs to be checked. Since you had a mechanic do the work are you capable of checking these things on your own, or are you just fishing for ideas to tell a mechanic about?
It definately sounds TPS related though. A simple search will give you the steps to adjust it, it is easy to do. Then set the idle and again a search will tell you how to do that, easy and quick. Even for a non-mechanical person you are probably looking at no more than a few hours to check and set the TPS and idle.
MI-Archangel
ok so I got the klze 1.5 years ago. klze ecu ms8 manifold and tb. Stage 2 act clutch. I have always had short ram intake even on my old engine. This problem started a couple weeks ago. I am not sure what it is but it is getting worse. Used to do it once every couple days now it did it twice while in the mcdonalds drive window. I gotta turn off the car and everyone must have thought i was a terrible driver. I am not sure what else you guys want to know except my intake fell half off once and we didnt know what it was and we messed with the tb cable a bit a month ago but not too much. The problem did start after that but not right after like a week or 2 after. my car has always idled really high like 1000rpm so i did the idle screw to get it down to 400 but when i take it out of gear while rolling to a stop it takes a long time to get back to normal idle usually sits at 1100rpms then finally drops. That has always been that way since the swap. I really do want your guys help i am just not sure what else you want to know?
- FIMotorMX-3
I also believe it's your throttle possition sensor. TPS. Mine is acting crazy at times. It revs sporatically at idle. usually between 1000 and 2000 rpms. I also had a problem with my throttle sticking open. May not be the problem if you are mashing on the gas and it doesn't eventually correct itself. Try spraying a little graphite or 3 in 1 oil, maybe wd40 on your throttle cable. Try to lube it up a little and also on the springs attached to your throttle body. If the cable or tb are sticking, that should help with that problem. But it does sound more like tps, which you would need to do a search on.
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain: http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
check out myspace:
