KLZE with ecu. I have recently been in idle and my car would rev to 3000 drop to 0 and do it all over again and again! Only does it in idle and only sometimes.
I was racing at the track and i shifted into third and drove for 1 second and it started almost bunny hopping ( no tire squeel) but it was like bogging out and s--- so i took it out of gear and then put it back in fourth and it was fine......
I spent so much fixing my engine and now this....
help me please
MI-Archangel
- MX-3 Money
pin 10 and ground reset idle,
check idle screw on the throttle body.
- vozaday2000
did you time your engine? i had that problem and i timed my engine and it almost fixed it 100%. it now only does the drop every once and a while and it is like 200rpm drop.
- FIMotorMX-3
Sometimes crazy idle can be due to a tps problem. It's a possibility but if it's doing it while you are driving, it's not likely.... Just an idea of something to check into. I think my tps is going, my car does some crazy sheet sometimes at idle. revving up to 2500 rpm and then dropping to a grand. Other times my car idles around850-900 and is fine. I'm not sure whether I should adjust my idle just yet because I have a feeling I'll be stalling occasionally when the car is idling properly... If the jumping around at idle sounds similar though, you might want to look into the tps being a problem.
sold it to a friend.93 green MX-3 with ZE swap. KL36 ecu, modified carbon fiber intake from a civic hatch. Centerforce Dual Friction clutch from MX-6. black Konig Minuz wheels, Synthetic fluids, 3 gauge pillar pod with air/fuel, water temp and oil press. Autometer Shiftlight. B&M short shifter. 2.25 piping with a Greddy SP1 muffler, AWR urethane front motormount, pheno spacers, Intrax Springs, Mazdaspeed Sideskirts. The New Ride is a 2003 1.8t a4
check out myspace:
http://profile.myspace.com/index.cfm?fu ... D795345349
my cardomain: http://www.cardomain.com/ride/2142324 UPDATED!!!! 08/28/06 newest pics
check out myspace:
