Hi,
Just wondered if anyone had bought a Fuel Pressure Booster Valve for their V6.
If so what are your impressions of it and was it worth 100quid?
Anyone bought a Power Boost Valve
I've just fittted a Green Cotton Induction Kit to my V6 and at the same time put in an FSE Power Boost Valve model number VK-384-TOY1-H. It was a bit fiddly finding a suitable place to mount it but is was a very simple job as everything you need comes in the box and was installed in 45-60 minutes.
And yes, it does make a difference! Throttle response which was already good is now great. Acceleration is noticably better and there are no flatspots in the RPM range. I have also put in a short shift gear change which makes changing through the gears when accelerating very smooth.
Can't say if or how it will affect fuel economy as i've only used half a tank since, most of which was racing around to see if everything worked. I didn't pay as much as £100, so all in all I am happy.
http://www.cardomain.com/ride/2194529
