so after alot of deliberation and comparisons between my wiring harness
and relisys3200s wiring harness it would seem my K8 is harness that i
used is missing a sensor.... which makes no sense to me.
The sensor which turns the fans off on the coolant neck isnt there. I have 4 sensors coming out of the harness and he has 5. However when i use the k8 ecu it turns off and on fine and when i had the k8 it worked fine.
... i have 2 extra ze harnesses in my garage but im still confused as hell...
where could it be... maybe chopped and hidden in the harness somewhere.
Not happy as i was gonna get that coolant swap thing done and now i have no wires to do it with.
Any ideas where or what else to look for?
wiring harness
wiring harness
