Temp Gauge faulty
Captain Clint
Temp Gauge faulty
I got a MX-3 Presso, the temperature gauge seems to be faulty. it fluxuates hot and cold all the time. Where does the temp probe sit and how would i check if it is faulty. If someone has a wiring diagram would help alot. thanks.
- ryanlindenberg
have you checked your thermostat? you should replace that first, your engine is probably actually fluctuating from hot to cold just like the guage says.
CARDOMAIN WITH UPDATED PICS
Captain Clint
Darcy
Umm.. no. It's connected to the coolant hose coming from the top of the radiator, driver's side (unless the Presso is different, which I doubt)
On the front part of http://www.mx-3.com is a link to "Online Shop Manual" under "Technical Info" on the left hand side. It is your friend. Make use of it.
- ryanlindenberg
yep it's located on the head...kinda below the disty (round thing with all the spark plug wires going to it. like the other guy said just follow the upper radiator hose and it will lead you right to it.
don't forget to buy the gasket too, and wait until the engine is cool or you will burn the crap out of yourself.
Captain Clint
