Very poor MPG :(
Tonestire
Very poor MPG :(
Hello all, I bought a '94 MX-3 with a 1.6dohc about 3 months ago and I am getting very poor gas milage. Last tank I got 14mpg and the tank before that was about 16mpg. I only drive about 8 miles per day. I have done the following maintance fixes with no change in the cars mpg.
New Plugs
New Wires
New Dist Cap & Rotor
New Fuel Filter
New CAI Filter
Checked for any intake leaks
New Valve Cover Gasket
New Ball joints % Tie rod Ends
Complete breakdown of intake throttle body, IAS including
a scrubdown, New gaskets, and adjusted and cleaned everything as in Tunes writeup
Checked air in tires and all are @ 44psi
Replaced O2 Sensor
I also tested and Cleaned all the EGR selenoids
Did Seafoam cleaner in brake vacuum 2 tanks ago
Ran Fuel injector cleaner 3 tanks ago
The car only has a few mods including a CAI, Aftermarket exhaust, and 17" low profiles tires/wheels. I dont run the A/C nor drive the car very hard. I am stumped and have no clue what to do next. Could this be a stuck injector or a problem with the fuel pressure regulator? Or possibly a bad Cat?
Any help is greatly appreciated.
Thanks Tony.
New Plugs
New Wires
New Fuel Filter
New CAI Filter
Replaced O2 Sensor
Thanks Tony.
---===Tonestire===---
1994 Mazda MX-3
1994 Mazda MX-3
- Tunes67
First thing I would do would be to do a compression test on your engine. Simple test to do, you can get a compression tester at any autoparts store and they are relatively cheap ($20 on up). You will find procedures in the online shop manual on how to do the compression test. When I bought my car at the end of January.. It too showed low mileage.. oddly enough.. same year and engine as yours. My problem turned out to be a burned valve. My #3 cylinder had almost no compression. (If you do a search you can find my original posts where I stumbled along before finding the problem LOL) Now my mileage wasnt quite as bad as yours.. I was averaging around 20 mpg. So you might have more than 1 burned valve. Another symptom of burned valves would be an relatively harsh idle. Just for reference.. My engine now shows 185 PSI in all 4 cylinders (after my machinist and I rebuilt the head and replaced all the exaust valves)
Another thing to check would be your initial timing. It should be around 10 degrees BTC. Again you will find procedures in the online shop manual on how to check it.
Is your car an ATX car or MTX? If ATX.. like me.. you got hosed LOL The ATX trans in these cars suck big time.. One of the more inefficient ATX's I have come across.. They sap horse power and as a result.. gas mileage. On top of that.. you have aftermarket rims as well. If those rims and tires weigh significantly more than the factory ones.. that will also affect your mileage adversely. Also.. the wider the rubber the more friction your power train has to over come to get your car rolling. Pizza cutter tires & wheels get better mileage than wide performance tires. Hope this helps out man. Post back with your findings.
Tunes67
Tunes67
Tonestire
Thanks for the speedy feedback Tunes. I'm picking up a Compression tester in a bit and will run the test tonight. I'll post results soon as I have them. My car is a Manual so that should help milage a bit. My car idles awesome the only problem with any idle issue is sometimes it will idle at 1k then like 1-3 seconds later drop down to 800rpms other times it idles down too 800rpms smoothly. My tires dont seem too much heavier then my freinds civics stock steelys but I havent put them on a scale to get actual weights.
I'll post some results after I leave my store.
Thanks again.
Tony.
Thanks again.
Tony.
1994 Mazda MX-3
1994 Mazda MX-3
Tonestire
Ok just did a compression test with the engine both hot and cold. Here are the results.
Cold:
Cyl 1 - 183, Cyl 2 - 181, Cyl 3 - 183, Cyl 4 - 179
Hot:
Cyl 1 - 182, Cyl 2 - 182, Cyl 3 - 182, Cyl 4 - 178
Are these ok???
I have reset and cleared out the ECU, also set it back up when I cleaned out the whole intake system with the 10 and ground jumper. I'm stumped other then a stuck injector. Every once in a while I do get a check engine light that comes on. If I down the key off then on it goes away. I'm not sure how to read codes and cant seem to find a walkthru on how to do it.
Tony.
Cold:
Hot:
Are these ok???
Tony.
1994 Mazda MX-3
1994 Mazda MX-3
- Flashpoint2
- mitmaks
how do you fix NOX readings, lean out car
- Tunes67
Yeah those compression numbers are great man.. no issue there.. try pulling CEL Codes and see what pops up from that. And check that initial timing
Tunes67
Tunes67
jimishadow
- Tunes67
Pulling codes is easy..
Jumper TEN and GND
Turn your key to the run position (do not start)
count the flashes from your CEL
There are a few posts around about it.. and once you have the codes there is a list of what the codes are. Cheers
Tunes67
Jumper TEN and GND
Tunes67
- Tunes67
CEL = Check Engine Light
And dont worry about appearing smart or whatever.. Intelligence isnt measured by knowledge.. its measured by what you do with your knowledge
Tunes67
Tunes67
- Tunes67
That would be code 16 then.. Grants has a list of all the codes on his website under "Info" hang on a sec and I will look it up.
Tunes67
Tunes67
