15in Maddnes!!
15in Maddnes!!
I got one 15 in my car already. I am going to try to stick 2 15in subs in my car. If my idea works i can fit 2 in but it will be pert tight on space. One of my freinds works at a wood place that makes cabnets and crap. We also make custom boxes for people on the weekends.
							1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
				reaper of souls
what kind of sub and how much air space do they need i have a box design to fit in the mx with 3 15in pheniox gold subs but you have to fiberglass out your sparetire well and mount your amps either in the box or under your seats
							 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.15in Maddnes!!
The box i was thinking is have 2 15in subs. 1 on each side of the car, they will be put in at a angle. Kind of verticly facing inworders with 2 ports in the middle. The subs and amps i am useing is all crossfire 2 bd2 subs with 2 200watt crossfire amp's. I got one of each in my car right now and it sounds good. I just want a more crazy bass sound then just one 15in sub that should be in a ported box but its not so i want to get a new setup.
				reaper of souls
cool well a sealed box is going to be easier to work with and depending on what the sub basket looks like you can save some space and inver the subs (magnets out) and get some serious bass responce and kick out of them i say go for it pound the crap out of them
(and get pics of the set up as well)
I am scared to ask what is the weight of that hole box.
