emergency brake signal light
luke_mx3
Post by luke_mx3 »
ok so when I accelerate quickly the light by my gauges comes on showing that the e-brake is engaged, but it isn't and i can't figure out why. Has this happened to anyone else?
Grants
BANNED Member
Post by Grants »
It also comes on if the brake fliud is low in the reserviour. Most likely cause.
relisys_3200
Post by relisys_3200 »
If the brake fluid is low, that light will come on. If thats the case, then make sure you check for leaks in your brakelines. This just happened to me 2 weeks ago.
Brandon
1992 MX-3 GS-ZE
Just ton confirm the brake fluid check...happened to me when my one caliper was leaking fluid
Andrew_Pakula
Post by Andrew_Pakula »
My brake light was coming on at random times, sometimes when accelerating, other times when I hit bumps on the road and usually it would go away. The problem was simply was that it was a little low on brake fluid, still had a fair amount but I guess it dropped to certain level where the censor kept going off.
