Air Conditioning blows warm air
Today I noticed the air conditioning is only blowing regular air, and not cold air.
What should I check to find out what is causing this.
Thanks.
Thanks.
- freyguy_412
I had that same problem when I got the car. But about a month later I looked under the hood and voila! No A/C. I have a button for it, and it lights up when I push it, but that isn't your problem. You need a recharge. Depending on the year, if it's the new stuff you can buy a freon recharge kit at your local autoparts store. Look on your a/c condensor and see if it says "134r" I think is the stuff you get in the store. If it's the older freon, you gotta go to a shop and pay like 45-60 dollars.
It might be slow, but it's not a civic!
- johnnyb
if you have a 93 you have R12. Which means you need to get your a/c system upgraded to R134a. you could do it yourself but you need to change the oilin the compressor, the fittings, the o-rings and you need to find a safe way to dispose of the R12. This job is best left to a professional because the R12 gas isnt environmentally friendly which is why the gas was changed to a more environmentally friendly R134a. The R12 isnt as readily availiable anymore and costs more then the R134a because of this, so in the long run the R134a is the better solution.
Have a look at this thread:
http://www.mx-3.com/phpbb2/viewtopic.ph ... onditioner
Also, you don't need to go to the expense and trouble of changing to R134A anymore - there are new gases that are a direct replacement now. Go to ebay.com and do a search for "refrigerant" and you'll find a stack of results.
- johnnyb
the replacement gas for R12 wont fix anything. This car may have a leak which is why there isnt any R12 left. So a replacement gas wont help anything. Its more economical to upgrade. Even though you can still find gases everyone has R134a and you're guaranteed with a mechanic to do it that the system has no leaks
You mean a place like meineke won't fix the leak when they are replacing the gas?johnnyb wrote:the replacement gas for R12 wont fix anything. This car may have a leak which is why there isnt any R12 left. So a replacement gas wont help anything. Its more economical to upgrade. Even though you can still find gases everyone has R134a and you're guaranteed with a mechanic to do it that the system has no leaks
How much does a place charge normally to upgrade and fill with r134a?
We don't know theres no R12 left yet - it could be the pressure switch, the clutch windings, or other numerous things.
I'd suggest checking the clutch for 12V first and then going from there depending what you find. If no 12V, check for pressure in the system. If theres some pressure - jump 12V to the clutch, rev to about 1500 rpm and watch the sight glass (obviously a set og gauges would help here but I'm assuming theres none available). If it looks full? work back through the pressure switch, any relays to the switch.
If it ends up being a leak, I'd fix it and top up with an R12 alternative rather than go to the expense of upgrading to R134A.
Keep in mind that with one top up of refrigerant you may get another 5 years of operation - theres always small leaks - hoses seep after time, and the compressor pulley seal is one that will always leak slightly, particularly if its not operated frequently to apply oil to the seals.
How would I check for pressure in the system?Grants wrote:We don't know theres no R12 left yet - it could be the pressure switch, the clutch windings, or other numerous things.
I also cannot find the sight glass.
Thanks for the help, I'll check tomorrow and update with what I find out.
- johnnyb
I guess.....
I was suggesting a permanent fix however but hey if you wanna temporarily fix it go ahead. But be warned if you just throw some R12 in there and it leaks out then you're gonna have to fix it anyways. And seeing as its inexpensive to upgrade to the R134a system why not do that rather then do it half assed and put refigerant in there. But hey its your car I'm just here suggesting the best solution for your problem.
And yes meineke will fix the problem. They'll pressurize your system and fix any leaks they find. But you could always ask to make sure because every mechanic might not be the same.
Yeah I definitely don't want to go half-assed.johnnyb wrote:I guess.....
If there is no pressure in the system, the first thing will be to get a quote from meineke.
Unless it is outrageous, I will just have them do it.
- mitmaks
know a guy that does $40 recharge
-Jim
