i have a 93 rs with around 210,000 miles on it, so the problem could be related to just about anything
the car starts fine, and will idle fine for 5-10 mins, then it wont hold idle. when accelerating, it pulls like a champ...but if i push the clutch pedal in, or come to a stop, the rpms fall and continue to fall until the car dies at 0 rpms. if im in neutral, it will die. if im in gear it drives fine until i press the clutch, then the rpms just fall all the way to zero.
it doesnt actually die until the rpms bottom out, so if im coming to a stop, i just put it in neutral and hold the throttle at 800-1000 rpms. i also hear a clicking sound coming from my passenger side firewall area when it is about to die. but, like i said, even if i do hear the clicking, i can blip the throttle and the car is fine.
it reminds me of a vaccum leak, but would a vaccum leak allow it to idle fine for the first 10 minutes? also, there are times that if i ease the rpms down, and not just let them fall abruptly it will idle fine for a few minutes...then it will just quit holding the idle and die.
any ideas? distributor cap? vaccum leak?
thanks for any suggestions!
