DEAD!
Car Stereo/Alarm Discussions
Kokiriwave
DEAD!
Post by Kokiriwave »
I took out the stock alarm, or an alarm system in the car.. unpluged everything and all..Then i did something stupid.
i switched the place of two plugs under the dash because i forgot where they went....and now everything in the car is DEAD! I mean the whole 9 yards, door locks, lights, even the annoying beep beep when you have the door open and the key in the ignition.. i checked a few fuses, and got nothing... :oops:
i need help desperately! I have to go to work tommorow!
I want MAZDASPEED!
MY WEBSITE:: http://kingmx.net
DJsMX-3
Post by DJsMX-3 »
Pull all fuses one by one and check,start with all inside the car and then the ones out in the enginebay..
Should do the trick unless you fryed some wires or some of the controlboxes :(
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
Typhoonk
Post by Typhoonk »
if everything is dead. Car won't start, no lights - check the 80amp fuse under the hood, on the drivers side. It's the main fuse from the battery.
PM for info
Pearl-JapSpec
Post by Pearl-JapSpec »
i remember when i installed my alarm, wires werent exactly same as described so i had to wing it, and i had the same problem, u probably crossed a power wire with the engine cut out... i know i did haha... but u said u pulled it all so i dont know....
Car Out Of Order For Now...
2 weeks In counting till re-incarnation!!
New G-Force Front Bumper!!
-_-_-_- Pics On Site -_-_-_-
http://members.cardomain.com/mx3_junkee
reaper of souls
Post by reaper of souls »
worse case if none of the fuses are blown the congraulation you just won the chance to by your self a new ECM check all wire goning in to the body copmuter and make sure none of them look cooked but hopefully it's just a few fuses blown i'd hate to see a fellow mxer have to spend 3G's on a new computer
Return to “Car Stereo/Alarm”
