Window Switch?
- solo_ryder
Window Switch?
Hi, I have a small problem with my window, I know its proly a switch but just making sure. The passenger window doesnt roll up or down when you use the passenger switch...but it works when you use the switch ont he drivers side...any ideas?
Also, how do you get that damn door off ont he passenger side?!? there some little bolt holding on in the middle but i cant seem to get anything in there to get it off!
lakersfan1
Bradmx32003
switch died...
Your switch died for the passenger side. at the moment i am after a driver side switch becuase i cant roll up my drive side window but i can roll it down.
1994 toyota supra single turbo
1994 Mazda MX-3 KL-ZE
If god owned a car... It would be a supra!!!
switch
well at this moment i am bidding on a new driver and passanger switch. and if you want i can sell you the passanger switch becuase i dont need it.
- XxantwawnxX
make sure that the switch that lets the passenger side be ablle to work in the first place is switched over...if not...the passenger side is never gonna work : )
on the left side (drivers side) under the power window switches for the left and the right side, there is another switch (mine says "POWER" with on and off). if this is to off, the passenger side window does not go down with the passengers side switch... but it does with the drivers side switch
another thing you could do is, what I've done, since my window would go down, but not up again... had to drive about 5 miles on an cold fall evening with my window down.. brrr.....
I disassembled the switch (caution-lots of small parts, springs, metall balls....) cleaned it with a brake-cleaner, cleaned hard dirt with very fine emery paper , applied some new grease, and assembled the whole stuff... and now it works pretty fine for 3 months...
hope this helps
hope this helps
georgechicken
We had this topic come up recently in the Email list... I have the same issue with my car, but it's not really anything not doing what it's told... I'd be willing to bet that a good handful of folks with this problem has a car that did not originally (brand new) have the 'auto-down' feature on the driver side switch, like mine, and has since had the driver switch replaced with one that has the 'auto-down' feature. I've had this happen with 3 of my 7 mx-3's, including the current. As soon as I can get a bit of free time, I intend to track down wiring schematics for both switches, and both cars' power window circuits, and see what it will take to make this issue go away. If anyone out there has the wiring schematics for the power window circuit, then either post a link here or email me at georgechicken@yahoo.com so that i can make an easy fix for us with this problem.. thanks!
Daniel
Daniel
--Maybe the Hippopotamus was just a really cool Apotamus.--
