BP FPRC
Posted: February 3rd, 2005, 9:20 pm
by johnboi85
i was wondering if you used the fpr solenoid from the bp or the sohc when you swap the motors? i'm using the sohc on the bp and it seems it's not running right? which do you use witht he bp?
Posted: February 3rd, 2005, 11:28 pm
by Jteezy
Use the bp one. I dont see how you got the one from the sohc to work because if you used the bp injector harness it wouldnt plug in. Take it easy. Peace
Posted: February 4th, 2005, 12:34 am
by johnboi85
i used the sohc injector harness. i just modified it. hey typhoonk which did u use?
Posted: February 4th, 2005, 2:06 am
by Shady469
i used a modified SOHC harness as well but i ran a vacuum line strait from the manifold to the FPR. I left the solenoid plugged up but it just doesnt have any vacuum lines going to it. Its worked well so far... (~1,200 miles and counting since the swap...)
Posted: February 4th, 2005, 7:15 pm
by Typhoonk
I just modified the wiring harness. I still used the BP fuel rail with the BP fuel pressure regulator on it.
