BP FPRC
BP FPRC
i was wondering if you used the fpr solenoid from the bp or the sohc when you swap the motors? i'm using the sohc on the bp and it seems it's not running right? which do you use witht he bp?
bp mx-3
- Shady469
i used a modified SOHC harness as well but i ran a vacuum line strait from the manifold to the FPR. I left the solenoid plugged up but it just doesnt have any vacuum lines going to it. Its worked well so far... (~1,200 miles and counting since the swap...)
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
