2.5L ECU, 1.8L TCM???
- masonholmes
Anybody happen to know if a 2.5L ECU from an ATX MX-6 will function correcly with a 1.8L TCM? I've got my 2.5L in and running with the K8 ATX attached...wondering if I can use the 2.5 ECU. I'll post my findings after I try it myself, but was just wondering. Also, if anybody happens to want to help me with the 2.5L ATX wiring in an MX-3, PLEASE DO. The K8 ATX seems have issues.
1993 MX-3 ~ SE * 2.5L Swap'd
1993 RX-7 ~ Rotary Performance Built
1996 MX-5 ~ M-Edition * Topless, Daily Driver
masonholmes@hotmail.com
- Aston Wards
- masonholmes
What does running in safe mode actually mean? Guessing I can't be hurting anything if I'm in a "safe mode". The 2.5 ECU went in lastnight and the engine is running and sounding much healthier - I just have the flashing Hold light and no use of the button itself. As long as I'm not hurting anything, I suppose I could live with this until I get the 2.5 ATX swap figured out - though it would be nice to get it running correctly until then too...
- masonholmes
also, how hard was setting up the AFC, and did the engine run at least as good as with the "correct" ECU?
- masonholmes
Update on the status of my 2.5L ATX MX-3... 2.5 ECU, 2.5 VAF, 1.8 ATCM. I've still got the flashing Hold light and believe have diagnosed the code, or at least what code it's throwing. Code 57, Reduce Torque Signal One. This code is supposed to tell the ECU to retard the engines timing by 6 degrees, in order to keep from frying the ATX. Now...having a 2.5 ECU and 1.8 ATCM running together, (with their possibly slight wiring differences), I'm not sure that this code is actually getting to the ECU or not. If it is, that means I'm losing a good deal of power right there, though I've still got enough to burn both front tires from a stop for three or four feet. Also, for the record, I still have no use of my Hold button on the shifter itself, though the transmission is shifting through all 4 gears just fine, on or off throttle.
- Aston Wards
- masonholmes
still going strong here, though not pulling any horse floats
and no use of the Hold button. I may temporarily put the 1.8 TCM back in until winter is over, so I can lock it in gears on hills etc.
- tehbrookzorz
Re: 2.5L ECU, 1.8L TCM???
I'm reviving another dead thread. Being that the ecu has three connectors, is it possible that one of the connectors is transmission related only? Could I somehow utilize both ecus; one to run the engine, the other for the trans?
Just curious.
Just curious.
Cody
