Easy Weight Reduction tips?
A forum for Drag Strip/Track Racing Discussions. (NO Street Racing or Kill Stories, they WILL be deleted.)
xXx_OTEP_xXx
Post by xXx_OTEP_xXx »
I'm going to the strip on Friday and I'm looking for some easy ways to reduce my car's weight..<p>So far I've removed my subs, taken out the spare tire and piece of wood over it, taken out the hatch cover, taken out the jack, and i'm working on removing the back seats and passenger seat now (those bolts are extremely tight :( )<p>anything that im forgetting? i dont really wanna take my dash apart..
Sold my 95 RS "Little Peanut" but she will never be forgotten. :(
maldo
Re: Easy Weight Reduction tips?
Post by maldo »
Remove the passenger seat. Go with 1/4-1/2 tank of gas. Remove the carpet, the insulation, the tar, etc. If you are really anal like me, a 1" hole saw works wonders at removing the last 1 or 2 grams ;)
torpedan
Post by torpedan »
yeah it dpends on how serious you want to be some weight reduction really cant be reveresd... yeah yanking the seats can reduce it a decent sum and the spare and what not... but unnless your really hard core into it dont do more than that.
-torp.
I don't own a Mazda.
maldo
Post by maldo »
Just finished removing all the tar on the floor of the car. Quickest way was to use dry ice, score the floor with a utility knife and then use a gasket scraper and hammer. The tar just pops off. Tomorrow I will be pulling out the welder and stitch welding the interior seems to reduce some of the flex in the chassis.
torpedan
Post by torpedan »
heheh sounds like fun.. how big of chunchs come out when using dry ice and how clean of a removal is it?
-torp.
ProtegeSTS
Post by ProtegeSTS »
run 2 spare tires on the rear. You wont lose much weight, but they'll have a LOT less drag. Run the pressurse high too. they won't overheat in a short drag race, so no worries.<p>also, the car needs to be as aero as possible. sounds silly, but it does help.
-93 MR2
#129 E-stock
maldo
Post by maldo »
When you score the tar, basically you are making 3"x3" squares, it chunks off in similar sizes.
Return to “Drag Strip/Track Racing”
