i have tokiko blue and suspension techniques and i dont know why! oh yeah i have a 92 gs. also when i hit a kinda big bump, it sounds like the strut hits the bottom of the car, if that makes any sense. the back never does that. also i know for a fact that the driver side cv axle or joint, not sure, could that be the problem. thanks for your help.
i almost forgot...im really thinking of getting stock/not lowered springs to replace the st springs. the reason for this is because i live in new orleans and we have the worst streets in the united states. and i cant afford getting all my suspension ruined. my springs are a couple of weeks old and ill probably sell them if i get new springs. does anyone know where i can get these oem spings or not lowered springs.
thanks for all the help.
front lower then back and makes noise
Tyler17rose
Re: front lower then back and makes noise
I'll happily trade you my stalk springs for your ST springs. Even if i have to put my car on jack stands for a week!
Mods:
craftydarren
The coils of your springs might be touching each other.
16" ASA wheels, Yokohama Prada Spec 2 tires, Tokiko Premium struts, H&R Lowering Springs.
mazdasport
I have the same setup and mine do the same thing... it does sound like they are hitting the underside of the car.
quicksliver
I have Suspension Technique lowering springs paired with ZX2 Struts. The coils do in fact hit eachother, i've already taken it in to have it looked at. It won't do any damage, i just live with the clunking.
thanks for all the replies. so this is kinda normal? im scared something wrong or something is gonna turn wrong. know what i mean. i would trade with you but im gonna wait a while to see what happens. sorry i couldnt answer earlier, i went on vacation ;]
i would greatly appreciate it if someone could tell me why they are hitting and what the cause of it is. thank you
