abs?and struts
jordanmx3
abs?and struts
Post by jordanmx3 »
what in the hell does struts and abs have to do with anything i want those kyb gr-2 struts but the guy at the shop says if i had abs? i said i don't know,but i got a fuse that has abs on the cover,but i also have the fuse in for power windows but i have roll downs. somebody help me out i'm getting that g-force bodykit and i don't want to crack it any time soon.
Swego
Re: abs?and struts
Post by Swego »
If you want to know if you have abs just slam the brakes: if the wheels lock, the tires scream you don't have abs. If you slow down, no tires screaming and the brake pedal jumps under your foot, you have abs.
