kyb need customizing to fit?
Posted: February 21st, 2002, 5:45 am
by furiousclouds
I just got a set of kyb gr2s and they dont fit my brake calipers on my v6. the bolts dont match up. is there some sort of part i need to match them to fit or did the guy just send me the wrong springs. also, is there anyone out there who completely changed their suspension to the spec of another vehicle.... say an entire corvette suspension (just poking around to see whats available.)
Re: kyb need customizing to fit?
Posted: February 21st, 2002, 11:22 am
by ProtegeSTS
wow, i dont even know what youre talking about.<P>KYBs make struts, not springs.<BR>Struts dont attach to the brake calipers.<BR>you cant interchange suspension parts.
Posted: February 21st, 2002, 1:16 pm
by David Coleman
Tekguy used Tokico Illuminatas from a MX-6 on his car with an adapter/spacer.<P> Image <P>I've heard that the new Celica suspension is fairly close to our dimensions also. Image
Posted: February 21st, 2002, 5:29 pm
by David Witherow
i put the kyb's my GS and had absolutly no problems getting them to fit and i did all the work in my driveway (accept the alignment ofcourse)
Posted: February 25th, 2002, 3:37 am
by jfbourgault
just out of curiosity what color where your gr2's, cause they usually are grey , but mine came in the kyb gr2 box, and to my amazement, they were black, but with gr2 badging. I e-mailed the rep at kyb and he told me that the color depends on where the were manufactured, <BR>so what color are they!<BR>and trust me, I know they are Gr2's, does'nt event compare with the stoct ones, they're so much better!
Posted: February 26th, 2002, 4:28 am
by Guest
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by David Coleman:<BR><STRONG>Tekguy used Tokico Illuminatas from a MX-6 on his car with an adapter/spacer.<P> Image <P>I've heard that the new Celica suspension is fairly close to our dimensions also. Image</STRONG><HR></BLOCKQUOTE><P>he did that because of the wieght of the 2.5 right! is there anymore detail into this! i was thinking of putting the whole mx-6 front suspension on my car to handle the extra wieght!
Posted: February 26th, 2002, 6:16 pm
by ProtegeSTS
if they use the same block, and the holes for the pistons are bigger on a KL, then where does the KL gain ALL this weight over the K8?
Posted: February 26th, 2002, 10:37 pm
by white fish
same weight give or take 50lbs
Posted: February 28th, 2002, 3:56 am
by Guest
from what i have heard its like 100 pounds more! thats just what i have heard from a few people! maybe because of the beefier intake manifold or something who knows! has any checked out the wieght difference in detail betweek the two|? :)
Posted: March 4th, 2002, 5:29 am
by furiousclouds
to all who gave legitimate responses... thank you. i appreciate your help. my gr2s are black and came in the gr2 box still the bolts on my STRUTS did not match up with my brake calipers at the bottom of the strut. i asked this to make sure i had the correct STRUT sent to me, or if they had sent one from another vehicle by mistake. this is obviously the case. secondly, thank you dave coleman for the insight as to the celica being close to ours. you obviously have common sense and could see where i was going with my inquiry. i thank mr coleman again, for i think i shall be using the celica suspension slightly modded to fit. thanks and <BR>bye<P>furious<P><I>DC: edited for content</I><p>[ March 05, 2002: Message edited by: David Coleman ]
Posted: March 4th, 2002, 5:38 am
by furiousclouds
and just for clarification the piece i am talking about is at the bottom of the strut in dave's foto. the mounts at the bottom with the 2 bolts and the nice brakeline beside it. which on my car have another bolt which also holds my caliper. those two bolts dont match up on mine so i believe they sent the wrong struts... in hindsight maybe i should have been a little more savvy and included pics like dave, yet i figured everyone here works on their cars and knew the mount i was getting at on the backside of the caliper.
Posted: March 7th, 2002, 5:32 am
by furiousclouds
dang dave... you took the bite out of it
Posted: March 7th, 2002, 5:02 pm
by David Coleman
Let's try to keep flames against other members off the board, ok?<P>Thanks :D
