3 2.25inch piping
1 2.25inch 90 degree bent piping( you can get this from jegs are a summit magizine)
1 down pipe flange
1 down pipe flange gasket
1 dsm 1st gen bov flange
)1 dsm bov flange gasket
1 oi1 return line(however much you think your going to need)
1 oil return line gasket
1 silicone 2.25inch to 2inch reducer hose
1 3inch hevay duty clamp
1 dsm 1st gen bov ( are whatever you prefer)
t3 garrett turbo (what ever turbo you choose)
custom manifold ( for us sohc mx's)
1 60inch long .25inch hard line
1 1/8inch npt male-to-male fitting
1 1/8inch npt female "T" fitting
1 1/8inch male-to 1/4inch pipe femalefitting
1 1/2inch i.d. rubber hose(1 foot )
oil filter 4 quarts of oil
hopefully i got everything up there and if its wrong then correct it like i said i got this otu of a magizine and wrote it down so hopefully it helps. most of the items up there you can get from pep boys.
