Turbo
Turbo
Ok, i just got a stock trubo off a i think, 93 talon. It's ported and i also got the intercooler and blow off valv,e for $250. I was wandering if any manifolds will fit or do i have to get one specially made. Also can anyone tell me what all parts i will need and if i can get them from a talon or anytihng else. Its a 93 mx-3 4 banger 5 sp., thanx alot
Re: Turbo
yeah, the fuel injectors are 440/450cc, snag'em.
for the manifold, get a log style made for around 2-350.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
- papa roached
Re: Turbo
anything past 7-8 psi you might wanna beef up the bottom end
