BPT swap ? (Running problem)
mclaw-mclaren
Hello, i just got the bpt swap done and it is having a few problems just wanna see if anyone has and ideas.
I have done, 255 fuel pump, Rx-7 MAF, stock injectors, S-AFC, ob1 wiring, gtx turbo ECU
here is the problem, it has problems starting i have to leave my key in the ON position for about 30 seconds before she will fire (when cold)if lucky
When it does get running, it idles really crazy. It may be at 900-1000 then drop down to 100-200 and u have to really give it gas to keep it running then it will shoot up again, and so on and so on. Once it is warm it does not do this, it idles a little rough but nothing really to worry about right now.
if u need to know what else is done let me know
THanks for your suggestions!
Travis
Travis
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
OsoSlo z28
Re: BPT swap ? (Running problem)
what ignition system are you running?
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
mclaw-mclaren
OsoSlo z28
try turning the key to start it w/o pressing in the clutch. stop, push in the cluch, then start the car.
<small>[ December 19, 2003, 12:54 PM: Message edited by: cre8v mx3 ]</small>
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
mclaw-mclaren
i tried that, still no go
thanks for replying so fast
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
mclaw-mclaren
mclaw-mclaren
mclaw-mclaren
ya i was thinking that may be it i got one of a 87 rx-7 not 88-89, i might just take it back and get one of a 92-93 mx-3
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
mclaw-mclaren
does anyone know if there is a difference between an automatic and 5spd MAF
thanks
thanks
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
Manach
Did you splice your SOHC wires? If not, the firing won't be ok until then..
Manach
Ex Mx'er with a Mx-3 1993..
Still in the Mazda Familly with :
-Mazda Rx-7 1987 GXL (Not running, one housing does not compress)
-Mazda Protege MazdaSpeed 2003.5 Titanium!
Still got 3 Engines!
- B6-ZE : Turbo Festiva project (Waiting donor car)
- BP-DE : Trader for a B6-ZE 1994 for parts upgrade in the Festiva project
- K8 : For sell. Pm me for info!
Once you go turbo, you can never go back!
Manach
88 and 89 MAF from Rx-7 are different..Originally posted by mclaw-precidian:
you need one from a 86-87-88. Marked B on it. Our stock one is marked S on it. There is a badge on it to tell from..
And btw, it is not a MAF, but a VAF, since it is using a trap door.. The 94+RS use a MAF. The GS always used a MAF
<small>[ December 26, 2003, 10:35 PM: Message edited by: Manach ]</small>
Manach
mclaw-mclaren
ya the wires were spliced, and i just changed it to a mx-3 MAF
thanks again for the suggestions
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
