tapping into the oil line.?
pelado
Re: tapping into the oil line.?
Post by pelado »
Visit your local hardware store and browse through the brass fittings section. Get a nipple, a tee, adapters, some tubing, and plumb a line from your oil pressure sensor by the oil filter to your turbo. Remove oil pressure sensor and plumb it to whatever part of the tee you don't use for the oil line.
VizualXTC
Post by VizualXTC »
If you have a V6 I've heard there is already a place on the block that has been capped that can supply oil. Also a really good write-up on installing a turbo on a K series engine is http://www.overboost.com/story.asp?id=115
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
boostedmx
Post by boostedmx »
the 4 cyl or the 6 cyl have the oil holes in their cyl. heads. they are a british thread so beware. i got my kit through jgs turbo. it comes with the t block that taps off the sending unit very nice kit with braided line and all. they also have a return kit but i found that it could be made from home depot fittings. <p>http://www.jgstools.com/turbo/
Return to “Forced Induction”
