I was going to turbo my 92 sohc mx3. I was going to use an fmu from vortech but im not sure of the ratio needed. If anyone has this ratio or another way to add fuel as boost increases this would be greatly appreciated.<p>
Ryan
fuel ratio for 92 sohc
Re: fuel ratio for 92 sohc
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by RG:
Ryan<hr></blockquote><p>Welcome to the board. If I understand your question you are asking what PSI/#boost ratio? the 12:1 should be sufficient. I imagine the cheaper route would be buying the B6T. It's only $800 (which is cheaper than basically any "good" custom turbo setup) and drops right in. (if I understand correctly) Good luck either way.
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Thanks for the info. Musch appreciated.
