how much psi can a stock DOCH take ?
- Casino
how much can it take ?<BR>and whats the compression ratio ?<BR>and the displacement ?<BR>i cant find the stock info anywhere help lol
Re: how much psi can a stock DOCH take ?
Ever hear of <A HREF="http://www.mx-3.com" TARGET=_blank>MX-3.COM</A>? All the specs for the motor are there or at least mentioned here.<P>The stock motor can handle 30psi easy. As to how long it can handle this is up to you. Ric hit 401rwhp on a stock BP motor running over 20+psi. Since the BP is just a stretched B6 it would be very possible. You would need to spend the money on a TEC/Haltech/Motec system. There is no easy answer. The crank can easily support 400-500hp, your rods can't. Try it and find out, thats the best solution.<BR>
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
- Casino
LOL yes ive heard of mx-3.com and ive looked throught it and i cant find the specs for the stock engine ? where is the link ?<BR>thanks for the info on the psi maldo its going to help
Online shop manual under specifications
Chris Malden
MX-3 RSR
MX-3 RSR
