Bpt with stock tranny
well i'm going over what i need for the bpt swap with my Mechanic and i'm going tho use the stock tranny cause i got it rebuilt 5000 kms ago so can i use my stock clutch and flywheel?
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Re: Bpt with stock tranny
Check the 4 CYL Faqs. My understanding is that the BPT uses a different input shaft diameter than the B6e, therefore it won't work. It uses the same as the BP miata. Talk to Ashley but I am guessing you will be buying a tranny before you do the swap.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by maldo:<BR><STRONG>Check the 4 CYL Faqs. My understanding is that the BPT uses a different input shaft diameter than the B6e, therefore it won't work. It uses the same as the BP miata. Talk to Ashley but I am guessing you will be buying a tranny before you do the swap.</STRONG><HR></BLOCKQUOTE><P>a couple days ago there was a post with some1 saying there was someone using there stock tranny with the bpt so i don't know
2004 RX-8 - Project
2004 RX-8 - Project
cre8e mx3 posted this<P>there's a guy running a bpt with no mods using the mx tranny..so that should give you an idea.<P>here <A HREF="http://www.mx-3.com/cgi-bin/ultimatebb. ... 3&t=001420" TARGET=_blank>http://www.mx-3.com/cgi-bin/ultimatebb. ... =001420</A> <P>cre8e mx3 do u know what flywheel and clutch that guy is using with the bpt and stock tranny
2004 RX-8 - Project
2004 RX-8 - Project
- jaydog5678
I read that post also. You can use the tranny and flywheel from the Mx-3 with the BP-T. This was suggested to me by Derrick at Corksport a LONG time ago but I have changed my views since than. You would need to run the 92-93 SOHC passenger axle to avoid modification if using the Mx gearbox. 94+ gearbox used a half-shaft or jack-shaft to eliminate torque steer, but this would make the bolt holes for the half-shaft bracket NOT line up on the BP-T engine. <P>You could use the Mx flywheel as it is noticeably lighter than the BP-T's. Their is a spline diff too, which means you must use a clutch built for the F25M-R gearbox. What clutch to use is up to you. I can't remember right now, but their are some clutches available for the Mx g.b.<P>I would reccomend the Protoge LX gearbox, simply because it is all bolt on. There are also aluminum flywheels and clutch packages. Not to mention LSD's available for this tranny which cure traction problems associated with high hp frt whl drive cars.<A HREF="http://www.srmotorsports.com" TARGET=_blank>www.srmotorsports.com</A>
what he said
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
lol k i got some of that but not all of it<P>i have a 93 sohc and i just had my tranny rebuilt and a new clutch put in 5000 km ago so i don't wanna swap trannys till a run the bpt with the turbo cause i'm gonna run it n/a for a couple months cause of lack of funds so will my tranny, clutch and flywheel work with the bpt??? (easy answer)
2004 RX-8 - Project
2004 RX-8 - Project
the bpt in n/a form? yes your stock clutch will hold up. once you add the turbo...the clutch will go away VERY fast.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
so it will bolt up<BR>to the bpt
2004 RX-8 - Project
2004 RX-8 - Project
i'd check with chris(maldo)or boostedmx about the sohc/doch bellhousing bolt patterns. i believe they are the same. as long as you use the mx flywheel, you should be fine. if in doubt, call derrick at CS.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
