Different types of turbos
Brainless
Post by Brainless »
Sorry but I don't know much about turbos, here are a few things I would like to know<P>What is Hybrid Turbo?<BR>What is Ball Bearing Turbo?<BR>People often refer to turbo as T-something, what is for example T-3 or T-66?<P>Thanks!!
Jonathan Michaud
93 Red RS
VizualXTC
Re: Different types of turbos
Post by VizualXTC »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Brainless:<BR><STRONG>Sorry but I don't know much about turbos, here are a few things I would like to know<P>What is Hybrid Turbo?<BR>What is Ball Bearing Turbo?<BR>People often refer to turbo as T-something, what is for example T-3 or T-66?<P>Thanks!!</STRONG><HR></BLOCKQUOTE><P>Hybrid means the compressor is off one turbo and the impeller is off another. With the t3/t4 hybrid. The impeller is off the t3 turbo to ensure quick spool, and the compressor is off the t4 to produce higher boost pressures.<P>The ball bearing turbos are turbos that use ball bearings on the shaft. Most are just lubricated with oil. The ball bearings make for a MUCH better turbo letting it spin at higher rpms, and also reduce the problem of coking the oil.<P>(coking is when the oil gets too hot and burns in the shaft. It will turn to a solid and eventually blow the turbo)<P>The T is a name given by Garret. like G is given by Mitsubishi. ex. T3/T4, 16G, etc.<P>go pick up Maximum Boost, it will really help you out
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
Return to “Forced Induction”
