injectors
injectors
Would it be a good idea to run 440cc injectors from a miata or a eclips if you dont have a turbo or super charger would i get more performance out of it?
				maldo
Re: injectors
Not worth it in NA trim.  Unless you are hitting well over 150whp there should not be any need.
							Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
						MX-3 RSR
				ProtegeSTS
				David Coleman
Re: injectors
There are injector options for K series engines.<BR> <A HREF="http://plaza.ufl.edu/mugen23/KL.htm" TARGET=_blank>http://plaza.ufl.edu/mugen23/KL.htm</A>
							David Coleman
