RPM of turbo turbine compared to super
antwawn
really i would just like to know what the average rpm of turbos or supercharger run at...
David Coleman
Re: RPM of turbo turbine compared to super
80-100k
David Coleman
mazda20
Side question same idea, What do most good turbos spool up at how high RPM's? Mine starts to spool at 2500 RPM to about 5 PSI and at 3000 RPM it is steady at 8PSI, Is this what most do?
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
antwawn
- mitmaks
stock 94 mitsu gt-gsx starts spooling at 3k's
maldo
I reach 10psi by the time the motor hits 3k rpm. You should start to see boost around 2000rpm on a turbo that is suited for street driving. If you are going drag only, you want it to kick in a little higher -- less broken axles that way.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
quinn_seipp
depends how big the turbo is, a bigger one needs higher rpm.
130 hp and 1000 horsepower strong,
How much boost can a supercharger put out?
As much as you want depending on what blower you have
