1.6 DOHC 4cyl NITROUS questions
THStrumpet
I have a '95 4cyl DOHC and I was wondering a few things:<P>1) What is the best brand that makes a nitrous kit for my car?<P>2) Wet or Dry?<P>3) Other than the kit, what else do I need to buy?<P>4) What kind of "shot" can my engine handle, if at all?<P>5) Is it really worth it?
L83R,
Joel
SpeedConcepts #11
I live my life a quarter mile at a time, nothing else matters, for those 22 seconds or more, I'm free.
Joel
SpeedConcepts #11
ProtegeSTS
Re: 1.6 DOHC 4cyl NITROUS questions
1) depends on #2<BR>2) depends on your opinion and goals<BR>3) colder spark plugs, depends on kit if you need anything else<BR>4) lots, depending on how much work you want to do to it.<BR>5) depends on you.....do you WANT 50 more hp?
-93 MR2
#129 E-stock
#129 E-stock
personally, i'm a fan of the zex nitrous kits. they only release the n2o under full throttle and they use the bottle pressure of your n2o to control the n2o-fuel ratio so it doesn't run too rich or too lean. you can check them out for yourself at <A HREF="http://www.zex.com" TARGET=_blank>www.zex.com</A>
and konstantine is walking down the stairs...
THStrumpet
I checked out the zex website, but they didnt have an application for ANY Mazdas!
L83R,
Joel
SpeedConcepts #11
Joel
SpeedConcepts #11
Stevech_2001
I'd stick with nitrous express it is a wet system (much safer and can run higher amounts or nitrous) I just don't like dry systems....
Steve
boostedmx
every system is designed to open at w.o.t. I dont know about the other kits but my NOS kit was well designed and had alot of customer support. it is a pro race fogger that is universal. it goes for a little over 600 bucks in jegs. little is needed after the kit is purchased, just your time.
