nos and turbo
mazda_mx3_1992
nos and turbo
maybe somebody can clear this up. one of my friends said you cant use nos while your running a turbo? is that true? if so, why?
"GREAT MINDS, THINK FOR THEMSELVES"
maldo
Re: nos and turbo
Not at all. It can be dangerous for the motor unless there is proper tuning but it can and has been done many times. Nitrous is used to spool turbos quicker in most cases.
Chris Malden
MX-3 RSR
chris.malden@sasktel.net
chris.malden@sasktel.sk.ca
MX-3 RSR
Stevech_2001
Re: nos and turbo
it can be done lot's of tuning equipment and a strong motor(built motor).... but to spool turbo's quicker is true but in that case it is because the turbo is the size of my head and has a lot of lag due to the fact that is all about high end hp's...how fast are you planning on going...turbo and nos.
Steve
mazda_mx3_1992
Re: nos and turbo
well i was planning on going with the bpt engine and vj-20 turbo and i just wanted to know if it wuld be worth it?
