Bolt-On Turbo?
- The_Great_Tonge
Bolt-On Turbo?
For the people that have done the gtx bolt on turbo for the 4-clyn how was it. What kind of power are you producing and what psi do you keep it at. Im thinking about doing this and just wanted osme info. Thanks
Re: Bolt-On Turbo?
I've done most of this I am still in the process, but it has not totally broke the bank to do it. I am currently running 9PSI no problems, with a VJ-14 Hybrid. It is sitting in my garage for now until I can get the fuel system right. I will have to make a few purchases to get the rich/lean situation right at all RPM's. Still can't get the Air/Fuel Mechanical guage hooked up because no knows which wire to connect to at the O2 sensor. Here is my cost so far.<P>VJ-14 Turbo and Manifold - $100.00 US<BR>Intercooler and BOV + Piping - $200.00 US<BR>Magnecor Wires and NGK Plugs - $57.00 US<BR>Gaskets - $15.00 US<BR>Labor - Free<BR>--------Purchases Pending (Estimates)<BR>RR FPR - $200.00 US<BR>RX-7 Fuel Pump - ???<BR>APEXI S-AFC - $320.00 US OR JDM S-AFC $100.00 US<BR>Fuel Injectors - $200.00 US
94 Mazda MX-3 BPT Custom Intake/Exhaust T3/T4, 51mm BOV, Tial WG, 2.5" Piping, 880cc Inj, Godspeed Intercooler, TEC II
My MX-3 Website
My MX-3 Website
- The_Great_Tonge
Re: Bolt-On Turbo?
Someone wanna rob a bank for me so I can do the set-up. Im a poor college guy and could use some help. Thanks!
Re: Bolt-On Turbo?
I forgot to mention gauges are necessary not optional use the best autometer at least a boost gauge and air/fuel ratio gauge I was able to get both of them off ebay for $109.00 US.
My MX-3 Website
My MX-3 Website
Re: Bolt-On Turbo?
i'd also suggest getting an egt. it's actually a better tuning tool than the a/f gauge.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
"MR." Ashley Fowler
cardomain pics
Re: Bolt-On Turbo?
Hey there I got a questions regaurding the set-up of a turbo. Most people which I know <BR>that have done this modification had there <BR>engines retro-fitted with proper pistons cams and special fuel injectors along with a new ecm and mass - air flow sensors. What have you guys done to the internals of your engines or is even required or not. <P>Thanks johnny
Re: Bolt-On Turbo?
it all depends on the amount of boost you want to run. with the stock b6e motor, you can run about 10psi safely. after that, you'll want to beef up the bottom end.
"MR." Ashley Fowler
cardomain pics
"MR." Ashley Fowler
cardomain pics
- jaydog5678
Re: Bolt-On Turbo?
I think it'll handle slightly more. just look at the Sept 2001 issue of Sport Compact Car. There is miata with bone stock internals, but he also has a $4,000 stand-a-lone ecu. With the right tunning and money of course, the B6's can handle more boost pressure. but spending that much money is not really worth it to some people.<P>[ March 31, 2002: Message edited by: jaydog5678 ]<p>[ March 31, 2002: Message edited by: jaydog5678 ]
