A pillar gauges
- papa roached
A pillar gauges
i got a universal pod and it wont work, are there any A pillars with gauge openings made for the MX-3?
- monty73741
Re: A pillar gauges
if you have a 95+ then www.gaugepods.com
or take a heat gun/hair dryer heat the pod & form it to the pod....or get a stock airpillar & start hacking & fiberglassin
Jason Danaher
Please Help Support MX-3.com
Re: A pillar gauges
On the guagepods website it says 1992 to 1995. Did they change the A-Pilars in 95?
						- monty73741
Re: A pillar gauges
[yeah in 95 no auto seatbelts
							Jason Danaher
Re: A pillar gauges
hey just wondering would this pillar fit a 94 auto, I have no auto belts so I thought I would ask. If not anyone know one that will other then the group by 1 ? I am intrested in a triple pillar or dual
						- bertz
Re: A pillar gauges
ok bringing up a old thread lol...ik that it only works for the 95 but if my auto seat belt dosn't work will i be able to use this on my 93gs like are the a-pillars the same style?
							-1993 Mazda Mx-3 GS 5 Speed - bought on October 31st 2008 - Engine specs: 1.8 Litter 24 Valve DOHC V6- http://www.Myspace.com/tyler.roberts" onclick="window.open(this.href);return false; - http://www.facebook.com/tbertz" onclick="window.open(this.href);return false; -
						Re: A pillar gauges
gaugepods.com sells one for the mx-3 with and one without auto seat belts.
Took the bp+t out of the mx and swapped it into a 95 escort wagon.
						- bertz
Re: A pillar gauges
yahh but wont the one that is for the auto seat belts have a slit in it? but it is the 3 pillar and not the 2 so i might have to do it.
						- Ryan
Re: A pillar gauges
Did you even read what he said?
- bertz
Re: A pillar gauges
maybe you just misunderstood me. Won't the pillar for the auto windows have a slit in it for the power window to move through it?  I don't want that I was just looking for a 3 pod pillar and just want a flush one without the potential slit.
						- RS_OBD'oh_2
Re: A pillar gauges
this boys cheese has fallen off his cracker.
You have only one option. The pillar pod for the auto seat belts. Deal with it.
Re: A pillar gauges
So let me get this straight... you have a 93 mx-3 with autobelts.  Your autobelts don't work so you want to get an A pillar gauge pod to cover up the track.  Here's why this won't work:
94-96 mx-3's don't have a track so the A pillar is about half as short so the pillar will only cover half of the track. If you use the A pillar from a 94-96 it's not going to fit properly and will require custom cutting/fitting. The A pillar from a 92-93 runs along the entire length of the track (about 4 feet long) and leaves a slit so the belt can run. If you truly want to do this right and "hide your track", you have 2 options:
option 1:
Get a 94+ headliner
Get 94+ A and B pillars
Get 94+ seatbelts
option 2:
Custom make an A pillar (and you will probably need to do this for both sides so it doesn't look weird on just one side)
What I would suggest is to buy the 92-93 pillar made for autobelts and use that
Why are you so worried about the slit anyways?
option 1:
Get a 94+ headliner
Get 94+ seatbelts
option 2:
- bertz
Re: A pillar gauges
Not really a big concern just didn't want anything gody looking. And havnt seen an actual picture of what they look like. But thanks for the info. Appreciate it.
