need help with gauge cluster...
ohthehumanity
i got this aluminum gauge bezel and i cant get into the cluster to install it
...i have a 93' GS, i unscrewed the 3 screws along the top, that loostened it, but i cant figure out whats holding it in there
1993 Mazda MX-3 GS - Metallic Blue
- johnnyb
Re: need help with gauge cluster...
to remove the cluster:<p>remove 3 screws in the molding at the top of the cluster(visible), remove the steering column cover(screws under wheel, pull off top cover), flip up rubber pieces 2 more screws are revealed remove them, unplug wiring for hazards and cruise(if applicable), 4 screws 2 top 2 bottom in cluster and voila cluster comes out, if you have an electronic dash there will be 3 plugs in the back of the cluster 2 on the passenger side of it and 1 on the driver side, unplug wires and slip cluster out
ohthehumanity
hey thank you so much, just installed it, reasonably painless!
