Altezza Question
Altezza Question
For anyone who knows something about Altezza lights, do you hook them up by just connecting the existing wires (ie..reverse bulb, signal bulb, brake bulbs) to the corresponding lights on the Altezza? Or, are altezzas completely different than normal tail lights??<P>Also, if a altezza light (ie..the altezza brake light, reverse, etc..) goes out, or burns out(if thats possible), how do you go about replacing it?? Is it as simple as going to an auto parts store and getting the bulb like a 1157, or do you need to special order them from the manufacturer(in this case Pakfeifer)???<P>Thanks.
- monty73741
Re: Altezza Question
altezzas refers to the stlye of taillights<BR>they should have the same bulbs <BR>the only issue in making them were <BR>the lights are mounted from the bottom<BR>so designing them were tricky plus with demand low no one wanted todo the R&D<P>jason
Jason Danaher
Please Help Support MX-3.com
