Complete with tranny and all parts needed to swap into a V^ mx-3.
Not including install, but how much do the parts cost for everything in CDN funds.,
thanks.
How much for a KL-ZE swap
uppitycracker
Re: How much for a KL-ZE swap
Well depending where you get your engine.
YOu can get the engine with tranny and ecu from osakajdmmotors.com. Thats 1200USD and they are in montreal. If you do that your still looking at 1000+ for other parts like Intake manifold, belts fluids, mounts, and so on.
Best way to go from what Ive seen is a-spec.ca they will do the complete swap including engine and tuning for 3000CND. They do it for a living, and its a good foundation to build on. Also if you call a month or so ahead they can source you a curved neck klze so you dont have to worry about finding one. Once you have it in there you can leave it or upgrade exhaust, ze ecu, clutch and so on. You would probably want a clutch for them to put on when you get the engine since stock clutch wont handle it.
<small>[ October 02, 2003, 05:49 PM: Message edited by: uppitycracker ]</small>
