6x9 in 92 mx3
DavePostle
6x9 in 92 mx3
does a 92 stock mx3 have back speakers that can be replaced easily with 6x9?
Mradio
Re: 6x9 in 92 mx3
not really, but you can easily fit 6 1/2 or 6 3/4 in the rear. For 6x9 you'll need to make a custom bracket. Good luck
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
- monty73741
Re: 6x9 in 92 mx3
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Dave Postle:<BR><STRONG>does a 92 stock mx3 have back speakers that can be replaced easily with 6x9?</STRONG><HR></BLOCKQUOTE><P>i saw it on someones site....look pretty easy....you just have to cut the inside of the speaker......and you have to add a custum speaker grill because most of the sound would stay in the enclosure<BR>jason
Jason Danaher
Please Help Support MX-3.com
Wheelz
Re: 6x9 in 92 mx3
For the rear it's easy. Just cut out the one cross piece that supports the existing speaker and a little bit of the edging. You need to angle the speaker downwards into the hole. Piece of cake.
1993 MX-3 RS/GS-R Under Construction
MX-3 Extreme
Re: 6x9 in 92 mx3
Just put a proper 6.5 coaxial speaker in the rear and call it a daY,this will sound better than any 6x9 will ever and you dont have to hack your car up,there is noway you can properly install a 6x9 in the placement of the stock 6.5 without making a total mess cause there is not enough space underneath to make a good 6x9 fit properly.if you cut out the top you will not be able to mount the speaker flush because it is not a perfectly flat surface.<P>Killer MX3
Re: 6x9 in 92 mx3
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Wheelz:<BR><STRONG>For the rear it's easy. Just cut out the one cross piece that supports the existing speaker and a little bit of the edging. You need to angle the speaker downwards into the hole. Piece of cake.</STRONG><HR></BLOCKQUOTE><BR>First of all, 50% of the sound would remain in the seatbelt enclosure, and that is kind of a POS install job. Why not do it right.<BR> <BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by KillerMX3:<BR><STRONG> Just put a proper 6.5 coaxial speaker in the rear and call it a daY,this will sound better than any 6x9 will ever and you dont have to hack your car up,there is noway you can properly install a 6x9 in the placement of the stock 6.5 without making a total mess cause there is not enough space underneath to make a good 6x9 fit properly.if you cut out the top you will not be able to mount the speaker flush because it is not a perfectly flat surface.</STRONG><HR></BLOCKQUOTE><BR>Not causin waves here, just need to correct that the stock speaker for all 4 speakers is 5.25"
~Ryan~
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
1994 MX-3 GS Teal
1987 Toyota Pickup
SR5 Xtracab Turbo
MX-3 Extreme
Re: 6x9 in 92 mx3
Sorry man but the speakers in all four corners is a 3 bolt pattern 6.5. done many of these cars and am one of the major mx-3 show competitors in canada. If you want a perfect fit 6.5 for mx-3 check all alpine 6.5 with multiple pattern and it will just screw right in with a little play.<P>Killer Mx3
