Ok i need some help here!!!
trentonsuncle@msn.com
I have a 92 mx3 v6 dohc and i took the intake manifold off and put it back on and now my car wont start. after i did it i read that you are supposed to un clip the gas clip from under the seat and i didnt know that when i did it so that might just be the problem so if anyone knows what to do about that or has any ideas on what i could have did wrong post a reply or email me at trentonsuncle@msn.com
- babyblueMX3
Re: Ok i need some help here!!!
leak ?
vaf aint't plug? or installed improperly?
did you reverse the fuel lines when you reinstalled the IM?
could be lots of thing..
I suggest that you describe EXACTLY what you done so we can source a problem..like what did you remove etc.
RIP 400whp ZE-T MX-3
Gro Harlem
vaccuum leak
DONATE TO MX-3.COM
DONATE TO MX-3.COM
ok what i did was i took the bolts out of the intake manifold then i unscrewed the filter deal thats on the end of the fuel lines then i inhooked the vacuum lines and then i took the manifold out and cleaned it then i put it back on exactley how i took it off. the car sounds like it normally did when i started it before but it doesnt sound like its getting gas. i read after i did this you should unclip the fuel pump from under the seat before you do this and i didnt do that what should i do? is there a way to get fuel through the fuel lines like priming it or something?
vaccum leak most likely.
