K8 and KLZE flywheel
mdavis
Hi. Can anybody tell me, are the flywheels from the K8 and the KLZE the same? Thanks
GS-R SE
Fixin's
- papa roached
Re: K8 and KLZE flywheel
they can interchange, the K8 flywheel is lighter
mdavis
thanks
Well then, do you know how much lighter? I think I heard the K8 was 18lbs.. I could easily be wrong, though. Next week when I swap the motors I want to shave the fly.. Anybody got any numbers? What can you tell me about the subject? Thanks
GS-R SE
Fixin's
- babyblueMX3
got my k8 FW shaved to 13 pounds...stock it's 17 IIRC..and all 2.5L FW are 22....don't go lower than 13 tough..you're on the border line of being safe
RIP 400whp ZE-T MX-3
mine is 13.6 lightened and balanced.
works like a charm... if you got a bit of cash go pick up a fidanza flywheel 9lbs and tough as hell and your car revs very quickly
13flat
isnt it a lil tricky to get your idle right w/such a light wheel though?
Goal: 1/4 mile time of 13.099 or better, N/A. ...still in the works
http://hits4pay.com/members/index.cgi?ittfund
- papa roached
mine is gonna be a pain, 9lb flywheel and 280 degree cams
mdavis
Hmm... I think I'll just have the K8's shaved to 14lbs.. How is street driving on 13-13.5? It is hard to move smoothly from a stop?
GS-R SE
Fixin's
- babyblueMX3
no problem driving around...the engine rev so quickly...i do have an underdrive pulley too that helps
doesnt make a difference for idle. aggressive cams and timing are what make a lopy idle.Originally posted by 13flat:
mdavis
What exactly do you mean "being safe"?Originally posted by babyblueMX3:
GS-R SE
Fixin's
- papa roached
anything lighter and your taking away from teh strength of the flywheel
- babyblueMX3
bubbaflaat
I have a shaved k8 flywheel, and a Under Drive pulley, revs nice. But i can't spin the tires going into 3rd like I could before! But that isn't a bad thing. It just was fun barking into 3rd!
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
- babyblueMX3
mine does still bark in third
...clutch helps a lot too...i got act z62 hdss
