1993 GS Sunroof leaking
I have a 1993 MX3 GS and the sunroof(metal) is leaking inside from the front right corner or front passenger side. There is water collected in the corner. I got an estimate for $500+ to disassemble and fix assuming the drain is clogged. Is there a way to know if the drain is actually clogged?I would like to get any suggestions to fix. The dealer where I purchased and has done all the maintenance, told me that I need a new sunroof!!! Thank you in advance for any help.
Re: 1993 GS Sunroof leaking
Your 3 posts consist of the same topic posted 3 times.<P>This is sad.<P><I>Post Closed</I><P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
