My cluch start making noise. it runs fine but when i push clutch when the engine runnig and during shifting, it sounds like metal against metal rubing. anyone know how to fix this problem,
than
Clutch
Clutch
92 Mazda Mx-3 V6 GS
Re: Clutch
Yes, its the throw-out (aka release) bearing. Needs replacing.
Re: Clutch
(aka release) bearing, where is that located at? is it easy to get to it?
92 Mazda Mx-3 V6 GS
- johnnyb
Re: Clutch
not really its inside the transmissionOriginally posted by Nathan Neises:
Re: Clutch
You might as well get a new clutch set and do the whole thing while you're in there.
