I need to replace the steering rack on my 92 GS. Is there a difference between the GS power steering rack and the RS power steering rack?
Are there any substitute steering racks that would reduce the lock to lock distance? From a FWD 323, MX-6, Protege, possibly even a Miata (I know it is a stretch)?
<small>[ April 05, 2004, 12:50 PM: Message edited by: Hy300 ]</small>
Steering Rack
Re: Steering Rack
Looking in the workshopmanual theres several differances so it seems like you cant swap steeringrack from a RS to a GS..
But i cant help you with the lock to lock question,but i would like to know myself,that would be a great mod i think
1992 MX-3 V6 Z1 Arbet VIII 17 x 8" -35mm Proracing Springs on KYB Sports, Corksport Strutbars, Brembo Cross Drilled & Slotted, Goodridge SS Brakelines, Corksport SS Clutchline, Mazdaspeed Enginemounts & Front arm bushings, All SRD bushings in shifterlinkage and cross member, Pacesetter Shortshifter, KN Conefilter, Custom SS Exhaust, Stereo Oldschool Goodies Denon & Phoenix Gold, Boston Pro & Cerwin Vega and lots of other small goodies
Re: Steering Rack
So that's a nope.
Re: Steering Rack
I looked at autozone and it lists a different part # for the MX-3, MX-6, 626, & 323. I even checked all the cars with 4 cylinders and 6 cylinders. That doesn't mean one of those won't swap in, justr that something about them is slightly different.
91 Eagle Talon Tsi AWD *RIP*
- papa roached
Re: Steering Rack
i hear the amount of turns lock to lock is 3.5 on a RS and 2.7 on the GS
