1.8 vs. 2.5 Transmission
ToyK
Post by ToyK »
Hy Guys,
got a question:
already done the engine swap, got a KL-03 from
a Probe. Swapped it including the 2.5 Transmission,
but in my oppinion it does not pull that good.
For sure, top speed is great (funny seeing the
needle at 240km/h), but i think the acceleration
is not that good (just a feel).
Has anyone ever tested both transmissions on the
engine (or with the KL-ZE) ?
Greetz
TK
IanL
Re: 1.8 vs. 2.5 Transmission
Post by IanL »
The fifth gear ratio of the Probe is higher than the MX-3. The others are the same. Acceleration in top may therefore feel a bit disappointing, but it should be heaps better in first to fourth.
Have you fitted the KLDE ECU, VAF and injectors?
ToyK
Post by ToyK »
Took the complete Engine including Transmission,
IM, ECU (KL07) and Air-Filter-Box.
Wireing-Harness is from the K8, just connect the
CEL output to the "HOLD"-Lamp. Also I changed
the front Valve-Cover, didn`t like the "Ford"-Sign
on it *g*
Pic from my Engine:
<img src="http://www.mx-3-community.de/bildertref ... pg&non_lr=" alt=" - " />
Greets
TK
IanL
Post by IanL »
Very nice, and I see you managed to get the straight neck IM in. I was wondering whether the sharp bend in the ribbed hose is a bit restrictive? A curved neck Millenia (Xedos 9) IM could be better?
ToyK
Post by ToyK »
Only Problem is to find one, Xedos 9 are very rarely here in Germany,
parts also.
Also I had no probs with fitting this IM in,
but there is no more space between Air Cleaner
and battery.
Greets
TK
tocixxx
Post by tocixxx »
Hello TK :)
I'll wirite english so that everybody can understand it.
The gear ratios are the same, exept the 5th which is longer. I think the 2,5l tranny from the MX-6 has different gear ratios.
92 GS-R, RX-8 Lightning Yellow, Complete Aresspeed Bodykit
http://www.cardomain.com/id/tocixxx
Mazda Speed & Style Club Austria http://www.mazdaclub.at
monstar-mx-3
Post by monstar-mx-3 »
I'm running a 2.5 tranny on a 1.8. I was getting tired of 3rd gear problem. But been in for a year and it going hard!
3rd gear problem?
monstar-mx-3
Yes. 3rd gear. On the old 1.08 tranny have huge problems on them. The snycro on 3rd gear always go. I hear that the AT trannies have problems too. I have stock one..last me three years...then it blew...bought a used one...oneyear later...3rd gear again...then drive like that for about a year..then last i upgraded to a 97...mx-6 tranny. Suppose to be stronger trannies. Been in for over a year now..and no problems.
papa roached
Post by papa roached »
i have heard the final drive on the 2.5L trannys are a bit higer than ours making the gears a bit longer
Mradio
Post by Mradio »
I have a probe transmission, and it's exactly the same.
I did alot of research on this topic a while back, and found out that mx3/probe/mx6 have same exact transmissions and gear ratios. Only 626 has a higher final ratio so your top speed will be higher.
Check out my ride and leave some feedback please!
http://www.cardomain.com/id/mradio007
Gro Harlem
Post by Gro Harlem »
nope...the transmissions are virtually identical including the final drive and all 5 gear ratios. There is No taller 5th gear.
DONATE TO MX-3.COM
2RotorsNaDream
Post by 2RotorsNaDream »
The MX-3 and Probe GT tranny are exactly the same. Thats why a Probe GT accelerates faster than the MX-6, cause it has lower gear ratios. The MX-6 and 626 have the same tranny cause theyre more for cruising. The MX-3 and Probe GT were more for sport.
Image1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...
1993 Teal MX-3 GS- KLZE and other goodies. RIP
mx3man83
Post by mx3man83 »
That intake manifold is not a straight neck, for the record. That is the kind that is from a domestic ford probe. They fit in the mx-3 with no problem whatsoever.
<small>[ February 12, 2004, 11:19 PM: Message edited by: mx3man83 ]</small>
My Cardomain site
HFStuart
Post by HFStuart »
Ian may well have been talking about the UK spec Probe which has the same overall gearing as an MX-6 or 626.
Stuart
