weight of motor
tilburgs82
weight of motor
does anyone know the weight of a K8 and a KLZE engine?
I want to know what the weightdifference is
- SE-Man
Re: weight of motor
my short block weighted in at 85lbs and each head at 25lbs, i just know that cuz they were all shipped.
sorry it was a K8
<small>[ February 02, 2004, 06:41 PM: Message edited by: SE-Man ]</small>
sorry it was a K8
2RotorsNaDream
Re: weight of motor
They're all light. Me and 2 friends were lifting my KLDE up into trucks and into backyards easily. And I'm only like 190lbs and my friends were only 180lbs and 220lbs. And we lifted the handtruck that the engine was sitting on. And the DE and ZE pretty uch weigh the same. A K8 is pretty much the same weight too, no noticeable difference.
1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...1993 Teal MX-3 GS- KLZE and other goodies. RIP
quicksliver
Re: weight of motor
You're body weight has hardley nothing to do with how much you can lift. Hell, im a toothpick at 135lb...but can lift a full sized keg of beer ~165lb with ease.
Re: weight of motor
I've seen it somewhere on this board that the KLZE weighs slightly less than the K8, because the cylinder bores are larger. You could argue that the pistons would weigh a bit more, but most people say there is little difference.
Gro Harlem
Re: weight of motor
My KLZE weighed in at about 290 lbs with the manifolds attached, no tranny, but the flywheel was on there (twas from an auto car).
I doubt there is a difference in the weight of the K8 to the KL motors
DONATE TO MX-3.COM
DONATE TO MX-3.COM
- mrspanky79
Re: weight of motor
<small>[ February 03, 2004, 12:50 PM: Message edited by: mrspanky79 ]</small>
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
Re: weight of motor
I think part of the story is that the block (which has the same external dimensions) has less material because the bores are bigger. The extra weight of pistons, etc works in the other direction. Short of actually weighing both engines, it could go either way, but its unlikely to be more than a couple of cans of beans.Originally posted by mrspanky79:
bigger bore would equal more weight you need more iron to make a bigger cycle, [/QB]
Street-Import
Re: weight of motor
The KLZE and K8 are about the same weight. Complete with the intake manifold and everything except the flywheel and tranny, they weight around 400 LBS.
I have 3 that I brought down in my basement so I have a pretty good idea
Tyler17rose
Re: weight of motor
The weight difference is small enough that you should worry more about how much gas you have in your tank then how much more or less the ZE weighs in at.
Mods:
- mrspanky79
Re: weight of motor
Yes the weight differents between the two are small that is not going to make a differents in the car
"I think part of the story is that the block (which has the same external dimensions) has less material because the bores are bigger."
have you ever seen in the block. It hollow so water flows aroud the cylander to cool the motor bigger bore larger iron sleves less water space.
"The extra weight of pistons, etc works in the other direction" what dos that mean weight is weight and most of the weight is on rotating parts so in motion it will have an even bigger effect and use more power to turn it. There is a reason why people go with lighter rotating parts(piston,rods, flywheels) save power and beter throtle respons.
99 vitara 4x4
99 vitara 4x4
