Page 1 of 2
VERY IMPORTANT QUESTION?
Posted: July 13th, 2003, 12:00 am
by BucktownMx3
Can u take the heads, cams, cam gears, and intake manifold, and valve cover gaskets and bolt it onto a 1.8 v6 without much of a problem? how hard would it be? ne thing extra u think i would have to get?
Re: VERY IMPORTANT QUESTION?
Posted: July 13th, 2003, 12:34 am
by atlantamx3
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BucktownMx3:
Can u take the heads, cams, cam gears, and intake manifold, and valve cover gaskets and bolt it onto a 1.8 v6 without much of a problem? <hr></blockquote><p>Take them from what?<p> :p <p>If you want an answer-- please be sure to really ask the FULL question to what you want to know.
Posted: July 13th, 2003, 12:45 am
by BucktownMx3
from a american kl-ze.
Posted: July 13th, 2003, 1:58 am
by BucktownMx3
and u dont have to be such a smart *** ok. everyone makes mistakes.
Posted: July 13th, 2003, 2:38 am
by mx34u2nve
hmm there is no american klze. the american 2.5l would eb the klde out of a probe or mx6. but to answer your question it is YES for the intake manifold valve covers but the others i honestly couldn't tell you. but whatever you can take out of a klze and put on yoru car you can take out of a klde
Posted: July 13th, 2003, 3:05 am
by Hy300
You could take everything but the internals from a KL, KF, or K8 and they'll bolt right up to any other without problems. You shouldn't interchange the heads though because putting KL heads on a K8 will decrease the compression ratio which isn't good.
Posted: July 13th, 2003, 5:46 am
by millionflame
and u dont have to be such a smart *** ok. everyone makes mistakes.<hr></blockquote><p>He can't help it. He was born without a brain.<p>
<p>~A
Posted: July 13th, 2003, 11:19 am
by lazzyie
You would be better off buying the 2.5 liter motor, Modding the 1.8 liter is like kicking a dying horse you won't get a lot of power out of it.
Posted: July 13th, 2003, 11:26 am
by BADMX3
is this the general idea about the mx3???
I don't think any insurance companies in the uk would insure a klze engined mx3. i don;t know whether to rebuild and turbo the 1.8 or fit a klze.
Posted: July 13th, 2003, 12:25 pm
by SimonPK
don't tell them - it looks identical from the outside!
Posted: July 13th, 2003, 2:20 pm
by BADMX3
yeah i guessed that but what about when it goes in for the yearly test / mot???
Posted: July 13th, 2003, 2:33 pm
by mmac
Insurance companies in the Uk WILL insure an MX-3 with KLZE, but you will have to search about, try kit car insurers, or companies like Adrian Flux who specialise in modded/tuned cars. Mine is insured by a company called Sabre through a Ins.broker named Thames City (0870 6061409).
I agree with Si, you would have to be a bit of Mazda enthusiast to spot it was a was a different engine (the only visible difference is that the In Manifold is a bit bigger). A few garage mechanics have had a look under the hood of my car and the only one who noticed it wasn't a 1.8 was the one who drove it.
by lazzyie
BadMX I think you guys have the 2.0 V6 readily avalible there these engines also produce 170hp that could be another choice.
Posted: July 13th, 2003, 2:54 pm
by mmac
The UK-spec Mazda V6's are the 1.8(135bhp), 2.0(145bhp), 2.5(165-168bhp).
You could if your very lucky maybe source a KLZE from a Jap import MX6, or 2.0 KFZE from an import 323/Lantis(I think that's the one Lazzyie is referring to)<p>The car will pass emissions on the MOT test as long as it is set up with the correct VAF/ECU combination(i.e. KLZE-JE50/KL36).
Relevant emissions levels for the 1.8 & 2.5 are the same so you don't have to tell them they are testing a 2.5. Your MOT certificate does not have the engine size or the engine number recorded on it.<p>[ July 13, 2003: Message edited by: mmac ]</p>
