VERY IMPORTANT QUESTION?
BucktownMx3
Can u take the heads, cams, cam gears, and intake manifold, and valve cover gaskets and bolt it onto a 1.8 v6 without much of a problem? how hard would it be? ne thing extra u think i would have to get?
94 mx3 gs (sold)
92 Mitsubishi Eclipse GSX(14.3 @ 99.08- almost completely stock)
- atlantamx3
Re: VERY IMPORTANT QUESTION?
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by BucktownMx3:
Can u take the heads, cams, cam gears, and intake manifold, and valve cover gaskets and bolt it onto a 1.8 v6 without much of a problem? <hr></blockquote><p>Take them from what?<p> :p <p>If you want an answer-- please be sure to really ask the FULL question to what you want to know.
BucktownMx3
from a american kl-ze.
94 mx3 gs (sold)
BucktownMx3
and u dont have to be such a smart *** ok. everyone makes mistakes.
94 mx3 gs (sold)
hmm there is no american klze. the american 2.5l would eb the klde out of a probe or mx6. but to answer your question it is YES for the intake manifold valve covers but the others i honestly couldn't tell you. but whatever you can take out of a klze and put on yoru car you can take out of a klde
Turbo 2.5l mx3
You could take everything but the internals from a KL, KF, or K8 and they'll bolt right up to any other without problems. You shouldn't interchange the heads though because putting KL heads on a K8 will decrease the compression ratio which isn't good.
- millionflame
and u dont have to be such a smart *** ok. everyone makes mistakes.<hr></blockquote><p>He can't help it. He was born without a brain.<p>
<p>~A
~ Millionflame (94 GS 120K)
You would be better off buying the 2.5 liter motor, Modding the 1.8 liter is like kicking a dying horse you won't get a lot of power out of it.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
is this the general idea about the mx3???
I don't think any insurance companies in the uk would insure a klze engined mx3. i don;t know whether to rebuild and turbo the 1.8 or fit a klze.
check my car domain
http://www.cardomain.com/ride/2144443
don't tell them - it looks identical from the outside!
yeah i guessed that but what about when it goes in for the yearly test / mot???
check my car domain
Insurance companies in the Uk WILL insure an MX-3 with KLZE, but you will have to search about, try kit car insurers, or companies like Adrian Flux who specialise in modded/tuned cars. Mine is insured by a company called Sabre through a Ins.broker named Thames City (0870 6061409).
I agree with Si, you would have to be a bit of Mazda enthusiast to spot it was a was a different engine (the only visible difference is that the In Manifold is a bit bigger). A few garage mechanics have had a look under the hood of my car and the only one who noticed it wasn't a 1.8 was the one who drove it.
1994 MX-3 ZE
BadMX I think you guys have the 2.0 V6 readily avalible there these engines also produce 170hp that could be another choice.
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
The UK-spec Mazda V6's are the 1.8(135bhp), 2.0(145bhp), 2.5(165-168bhp).
You could if your very lucky maybe source a KLZE from a Jap import MX6, or 2.0 KFZE from an import 323/Lantis(I think that's the one Lazzyie is referring to)<p>The car will pass emissions on the MOT test as long as it is set up with the correct VAF/ECU combination(i.e. KLZE-JE50/KL36).
Relevant emissions levels for the 1.8 & 2.5 are the same so you don't have to tell them they are testing a 2.5. Your MOT certificate does not have the engine size or the engine number recorded on it.<p>[ July 13, 2003: Message edited by: mmac ]</p>
1994 MX-3 ZE
