does all 2.5L will fit exactly with the mounts of 1.8?
Posted: May 8th, 2003, 6:22 pm
by khas
Does all 2.5 fit exactly with my stock 1.8 mounts or is there any engines codes ..or years that will fit better .Thx
Re: does all 2.5L will fit exactly with the mounts of 1.8?
Posted: May 8th, 2003, 6:36 pm
by Custommx3
I believe 1 or 2 motor mounts have to be moved, but you can use your stock mounts.
Posted: May 8th, 2003, 6:48 pm
by khas
all the holes(2) are made .only have to bolt it at the other place, with no other modification.thx for replies
Posted: May 9th, 2003, 12:54 am
by Nd4SpdSe
i havent read anything on moving mounts...Which mounts do you move?<p>[ May 09, 2003: Message edited by: Nd4SpdSe ]</p>
Posted: May 11th, 2003, 4:08 pm
by pDhMiBsh
Yea which ones do you move? I need to know that too? also will the 4 cyl body engnie mounts work with the 6cyl engine?
Posted: May 13th, 2003, 11:33 pm
by Buff1110
i just installed mazdaspeed mounts with my klze with ms8 manifold and everything lined up perfectly. no relocating or drilling additional holes. i used k8 mounts.
