leaking roof
leaking roof
I've got water coming down on top of my seatbelts in the body of the car and it's ending up under the back seat and on the floor in the back. forgot to mention it doesn't happen when i park pointing down a hill. Well any way is it possible to find and fix it by taking the sunroof off (unless its magically coming through the body) or do I have to start taking the interior apart.
'92 MX3 1.8 V6
G-MAX 40mm lowering springs
'91 AZ3 1.5 35mm drop +V6 stryt brace.
khas
Re: leaking roof
I had this problem too. But the water was coming from the front, beside of my pedal. I've took off the carpet and patched it with silicone stuff. It was a weak weld in the front wing down beside my pedal. But if you say it comes from the top..cant help you.(I tought it was coming from the top too)
