No Spark
No Spark
Finished engine swap, put in klze. But there is no spark when I go to turn it on. Should I use klze distributor or can I use mx-3 distributor? I am currently using 1.8 ecu and airflow meter.
Re: No Spark
Dope another Mx-3 in SD with a ZE engine!! You can use the mx-3 disty just fine. You know we are screwed on smog laws right!
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
aaronthehic
Re: No Spark
the ze disty does not have a coil in it so you don't want it unless you want to set that s*it up<p>check connectors ,fuses (inside + engine bay), check coil resistence and ignitor resistence , do you have a 95+ model? (obd2 is diferent) If every thing checks out ok it is most likly the disty because I had the same problem last year and you can not directly check the disty you have to eliminate every thig else. it is frustrating.
I would also think it is a connection problem cause you just did the swap.
13.023 @ 105 mph
Re: No Spark
Grounds Make sure you check all of the grounds!!
96 Integra LS DD
91 Crx Si drag car
96 Integra LS DD
91 Crx Si drag car
Re: No Spark
well i swapped the ze ditributor for my 1.8, I do have spark but still wont start. I pulled the fule line off right before the regulator, and I have fule, so now I'm lost.
